Can anybody provide me a simple bash script sample which will produce important system health report consisting hardware resources via email ?
System health bash script ?
While there are many scripts available depends on the need of system report. You can use following script which will give detail report for,
- Mounted File Systems
- Read-only File System If Any
- File Systems Disk Usage
- Inode Usage
- Zombie Processes If Found
- RAM Utilization
- SWAP Utilization
- CPU Utilization
- Current Load Average
- Top 5 memory & CPU consuming resources.
Create file /root/system-health.sh file and add following code then give 755 permission to file..
Code:#!/bin/bash ##----------Created By Swapnil at 24x7servermanagement.com -----------------------------## ##---------- Purpose : To quickly check and report health status in a linux system.----------## ##---------- Tested on : RHEL/Centos-7/6, Ubuntu16----## ##-----NOTE: This script requires root privileges, otherwise you could run the script -------## ##---- as a sudo user who got root privileges. ----------------------------------------------## ##----------- "sudo /bin/bash <ScriptName>" -------------------------------------------------## S="************************************" D="-------------------------------------" mount=$(mount|egrep -iw "ext4|ext3|xfs|gfs|gfs2|btrfs"|sort -u -t' ' -k1,2) disk=$(df -PTh|egrep -iw "ext4|ext3|xfs|gfs|gfs2|btrfs"|sort -k6n|awk '!seen[$1]++') inode=$(df -PThi|egrep -iw "ext4|ext3|xfs|gfs|gfs2|btrfs"|sort -k6n|awk '!seen[$1]++') #--------Checking the availability of sysstat package..........# if [ ! -x /usr/bin/mpstat ] then printf "\nError : Either \"mpstat\" command not available OR \"sysstat\" package is not properly installed. Please make sure this package is installed and working properly!, then run this script.\n\n" exit 1 fi echo -e "$S Health Status Report $S" echo -e "\nOperating System Details" echo -e "$D" printf "Hostname :" $(hostname -f > /dev/null 2>&1) && printf " $(hostname -f)" || printf " $(hostname -s)" [ -x /usr/bin/lsb_release ] && echo -e "\nOperating System :" $(lsb_release -d|awk -F: '{print $2}'|sed -e 's/^[ \t]*//') || echo -e "\nOperating System :" $(cat /etc/system-release) echo -e "Kernel Version :" $(uname -r) printf "OS Architecture :" $(arch | grep x86_64 2>&1 > /dev/null) && printf " 64 Bit OS\n" || printf " 32 Bit OS\n" #--------Print system uptime-------# UPTIME=$(uptime) echo $UPTIME|grep day 2>&1 > /dev/null if [ $? != 0 ] then echo $UPTIME|grep -w min 2>&1 > /dev/null && echo -e "System Uptime : "$(echo $UPTIME|awk '{print $2" by "$3}'|sed -e 's/,.*//g')" minutes" || echo -e "System Uptime : "$(echo $UPTIME|awk '{print $2" by "$3" "$4}'|sed -e 's/,.*//g')" hours" else echo -e "System Uptime :" $(echo $UPTIME|awk '{print $2" by "$3" "$4" "$5" hours"}'|sed -e 's/,//g') fi echo -e "Current System Date & Time : "$(date +%c) #--------Check read-only file systems--------# echo -e "\nChecking For Read-only File System[s]" echo -e "$D" echo "$mount"|grep -w \(ro\) && echo -e "\n.....Read Only file system[s] found"|| echo -e ".....No read-only file system[s] found. " #--------Check currently mounted file systems--------# echo -e "\n\nChecking For Currently Mounted File System[s]" echo -e "$D$D" echo "$mount"|column -t #--------Check disk usage--------# echo -e "\n\nChecking For Disk Usage On Mounted File System[s]" echo -e "$D$D" echo -e "( 0-90% = OK/HEALTHY, 90-95% = WARNING, 95-100% = CRITICAL )" echo -e "$D$D" echo -e "Mounted File System[s] Utilization (Percentage Used):\n" echo "$disk"|awk '{print $1 " "$7}' > /tmp/s1.out echo "$disk"|awk '{print $6}'|sed -e 's/%//g' > /tmp/s2.out > /tmp/s3.out for i in $(cat /tmp/s2.out); do { if [ $i -ge 95 ]; then echo -e $i"% ------------------Critical" >> /tmp/s3.out; elif [[ $i -ge 90 && $i -lt 95 ]]; then echo -e $i"% ------------------Warning" >> /tmp/s3.out; else echo -e $i"% ------------------Good/Healthy" >> /tmp/s3.out; fi } done paste -d"\t" /tmp/s1.out /tmp/s3.out|column -t #--------Check zombie processes--------# echo -e "\n\nChecking For Zombie Processes" echo -e "$D" ps -eo stat|grep -w Z 1>&2 > /dev/null if [ $? == 0 ] then echo -e "Number of zombie process on the system are :" $(ps -eo stat|grep -w Z|wc -l) echo -e "\n Details of each zombie processes found " echo -e " $D" ZPROC=$(ps -eo stat,pid|grep -w Z|awk '{print $2}') for i in $(echo "$ZPROC") do ps -o pid,ppid,user,stat,args -p $i done else echo -e "No zombie processes found on the system." fi #--------Check Inode usage--------# echo -e "\n\nChecking For INode Usage" echo -e "$D$D" echo -e "( 0-90% = OK/HEALTHY, 90-95% = WARNING, 95-100% = CRITICAL )" echo -e "$D$D" echo -e "INode Utilization (Percentage Used):\n" echo "$inode"|awk '{print $1" "$7}' > /tmp/s1.out echo "$inode"|awk '{print $6}'|sed -e 's/%//g' > /tmp/s2.out > /tmp/s3.out for i in $(cat /tmp/s2.out); do if [[ $i = *[[:digit:]]* ]]; then { if [ $i -ge 95 ]; then echo -e $i"% ------------------Critical" >> /tmp/s3.out; elif [[ $i -ge 90 && $i -lt 95 ]]; then echo -e $i"% ------------------Warning" >> /tmp/s3.out; else echo -e $i"% ------------------Good/Healthy" >> /tmp/s3.out; fi } else echo -e $i"% (Inode Percentage details not available)" >> /tmp/s3.out fi done paste -d"\t" /tmp/s1.out /tmp/s3.out|column -t #--------Check RAM Utilization--------# memory=$(cat /proc/meminfo) echo -e "\n\nChecking Memory Usage Details" echo -e "$D" echo -e "Total RAM (/proc/meminfo) : "$(echo "$memory"|grep MemTotal|awk '{print $2/1024}') "MB OR" $(echo "$memory"|grep MemTotal|awk '{print $2/1024/1024}') "GB" echo -e "Used RAM in MB : "$(free -m|grep -w Mem:|awk '{print $3}')", in GB : "$(free -m|grep -w Mem:|awk '{print $3/1024}') echo -e "Free RAM in MB : "$(echo "$memory"|grep -w MemFree|awk '{print $2/1024}')" , in GB : "$(echo "$memory"|grep -w MemFree |awk '{print $2/1024/1024}') #--------Check SWAP Utilization--------# echo -e "\n\nChecking SWAP Details" echo -e "$D" echo -e "Total Swap Memory in MB : "$(echo "$memory"|grep -w SwapTotal|awk '{print $2/1024}')", in GB : "$(echo "$memory"|grep -w SwapTotal|awk '{print $2/1024/1024}') echo -e "Swap Free Memory in MB : "$(echo "$memory"|grep -w SwapFree|awk '{print $2/1024}')", in GB : "$(echo "$memory"|grep -w SwapFree|awk '{print $2/1024/1024}') #--------Check CPU Utilization (current data)--------# echo -e "\n\nChecking For CPU Utilization" echo -e "$D" echo -e "Manufacturer: "$(dmidecode -s processor-manufacturer|uniq) echo -e "Processor Model: "$(dmidecode -s processor-version|uniq) if [ -e /usr/bin/lscpu ] then { echo -e "No. Of Processor(s) :" $(lscpu|grep -w "Socket(s):"|awk -F: '{print $2}') echo -e "No. of Core(s) per processor :" $(lscpu|grep -w "Core(s) per socket:"|awk -F: '{print $2}') } else { echo -e "No. Of Processor(s) Found :" $(grep -c processor /proc/cpuinfo) echo -e "No. of Core(s) per processor :" $(grep "cpu cores" /proc/cpuinfo|uniq|wc -l) } fi echo -e "\nCurrent Processor Utilization Summary :\n" mpstat|tail -2 #--------Check for load average (current data)--------# echo -e "\n\nChecking For Load Average" echo -e "$D" echo -e "Current Load Average : $(uptime|grep -o "load average.*"|awk '{print $3" " $4" " $5}')" #--------Print top 5 most memory consuming resources---------# echo -e "\n\nTop 5 Memory Resource Processes" echo -e "$D$D" ps -eo pmem,pcpu,pid,ppid,user,stat,args | sort -k 1 -r | head -6|sed 's/$/\n/' #--------Print top 5 most CPU consuming resources---------# echo -e "\n\nTop 5 CPU Resource Processes" echo -e "$D$D" ps -eo pcpu,pmem,pid,ppid,user,stat,args | sort -k 1 -r | head -6|sed 's/$/\n/'
After that setup following cronjob which will execute after every 24 hours..
Code:0 1 * * * /root/system-health.sh 2>&1 | mail -s "Server Health Check" [email protected]
- Likes 1
