How To: Install CS-Cart on a Host with cPanel
  • How To: Install CS-Cart on a Host with cPanel
    Installing CS-Cart on a host with cPanel is a relatively straightforward process. Here are the steps to follow:
    1. First, log in to your cPanel account and navigate to the "File Manager" section.
    2. In the File Manager, create a new directory where you want to install CS-Cart. You can name this directory anything you like, but make sure it's easy to remember.
    3. Download the latest version of CS-Cart from their official website. You can download the installation files as a zip archive.
    4. Upload the zip archive to the directory you created in step 2 using the "Upload" feature in cPanel's File Manager. After uploading the archive, right-click on it and select "Extract" to extract the installation files.
    5. Once the files are extracted, navigate to the directory where you uploaded them using your web browser. For example, if you created a directory called "mycart" in your public_html directory, you would navigate to http://yourdomain.com/mycart.
    6. Follow the installation wizard to configure CS-Cart. You'll need to enter your database information, create an admin account, and choose some basic settings for your store.
    7. After completing the installation, delete the installation directory and rename the "config.local.php" file to "config.php". This file contains your store's configuration settings and should be kept secure.
    That's it!
