A Step-by-Step Guide to Installing Opigno LMS - The Best Drupal Based LMS
  • A Step-by-Step Guide to Installing Opigno LMS - The Best Drupal Based LMS
    Opigno LMS is a powerful open-source learning management system built on Drupal, a popular content management system. Opigno LMS has gained popularity due to its flexibility, ease of use, and its ability to provide a customizable e-learning experience for both small and large organizations. In this guide, we will provide a step-by-step guide on how to install Opigno LMS and get started with creating and managing e-learning content.
    Step 1: Check the system requirements
    Before you begin, make sure your server meets the minimum requirements for running Opigno LMS. Opigno LMS requires PHP 7.2 or higher, MySQL 5.7 or higher, and Apache 2.4 or higher. Additionally, you will need to have Drupal 8.8 or higher installed on your server.
    Step 2: Download and Install Opigno LMS
    To install Opigno LMS, you can either download the latest version from the Opigno website or use Composer to install it. Using Composer is the recommended method, as it ensures that all dependencies are installed correctly. If you choose to download the package directly, you will need to extract the files and upload them to your web server.
    Step 3: Create a Database
    Next, you will need to create a database for Opigno LMS to store its data. You can create a new database using phpMyAdmin or any other database management tool. Make sure to note down the database name, database username, and password for later use.
    Step 4: Run the Installation Script
    Now, you are ready to run the installation script. Navigate to the Opigno LMS URL on your web browser and follow the on-screen instructions to complete the installation. You will need to provide your database details, admin account details, and other settings during the installation process.
    Step 5: Configure Opigno LMS
    Once the installation is complete, you can log in to your Opigno LMS site and start configuring it. Opigno LMS provides a user-friendly interface that allows you to customize the site, create courses, and manage users easily. You can also install additional modules and themes to extend the functionality of Opigno LMS.
    In conclusion, Opigno LMS is a powerful learning management system that provides a customizable e-learning experience for organizations of all sizes. By following these simple steps, you can install Opigno LMS on your server and start creating and managing e-learning content. We hope this guide has been helpful, and we wish you all the best with your Opigno LMS installation!
    Opigno is a Learning Management System based on Drupal aimed at managing online courses. It provides an end-to-end LMS solution based 100% on Drupal technology.
