Given that your MySQL database is running on a cPanel server, here are specific steps to troubleshoot and resolve the "Error establishing a database connection":
1. Verify Database Credentials:
- Ensure the database name, username, password, and hostname are correct.
- In cPanel, navigate to MySQL Databases to check the correct database name and user.
- Verify the user has been assigned to the database with the correct privileges.
2. Check Database Server Status:
- In cPanel, navigate to Server Status or Service Status to ensure the MySQL server is running.
- Restart the MySQL service if necessary.
3. Inspect Configuration File:
- Ensure your application's configuration file (e.g., `wp-config.php` for WordPress) has the correct database settings.
- Example for WordPress:
4. Check MySQL User Privileges:
- In cPanel, go to MySQL Databases and ensure the user associated with your database has all the necessary privileges.
- Click on Check User Privileges to confirm.
5. Test Connection Manually:
- Use the cPanel Terminal or an SSH client to manually connect to the database.
- Enter the password and try to access the database to confirm connectivity.
6. Review MySQL Error Logs:
- Check the MySQL error log for any specific errors that might indicate the problem.
- The log is usually located at `/var/lib/mysql/hostname.err` or similar, depending on your cPanel setup.
7. Database Overload or Resource Limits:
- Check if your database is experiencing heavy load or has hit resource limits.
- In cPanel, look at Resource Usage to check if your account is exceeding limits.
8. Database Corruption:
- Run a repair on the database tables using phpMyAdmin:
- In cPanel, open phpMyAdmin.
- Select your database, check all tables, and from the drop-down menu, select Repair table.
9. Firewall and Network Issues:
- Ensure there are no firewall rules or network issues blocking the connection.
- Check cPanel's firewall settings to ensure MySQL connections are allowed.
10. Update and Maintenance:
- Ensure your cPanel and MySQL installations are up to date.
- Apply any pending updates and patches.
If you are still facing issues, you can contact your hosting provider for further assistance, as they may have specific insights or tools to diagnose and fix the problem on their cPanel environment.
define('DB_NAME', 'your_database_name');
define('DB_USER', 'your_database_user');
define('DB_PASSWORD', 'your_database_password');
define('DB_HOST', 'localhost'); // or your database server's IP
sh mysql -u your_database_user -p
