RAM on Linux
  • RAM on Linux
    How to check total installed RAM on the Linux server?
    Hello,
    You may use the either below commands to check the RAM installed on a linux server.
    The below output will give the result in MB.
    root@server [/]# free -m
    total used free shared buffers cached
    Mem: 15906 15458 447 5 3022 6880
    -/+ buffers/cache: 5554 10351
    Swap: 4095 67 4028
    Whereas, the same result can be obtained in GB for better understanding.
    root@server [/]# free -g
    Mem: 15 15 0 0 2 6
    -/+ buffers/cache: 5 10
    Swap: 3 0 3
    The above output states that the server is deployed with a total of 15 G RAM and an additional SWAP space of 3 G. The used column shows how much RAM is being used up by the server.
      You can get the information you require by following 2 ways:
      # cat /proc/meminfo
      # dmidecode -t memory
