Horde DB error showing in cPanel
  • Horde DB error showing in cPanel
    I am getting the following error while accessing the cpanel.
    Can someone advise on this?
    It seems that the SQLite DB wasn't created for that user, You can try the following command to fix this issue.
    /usr/local/cpanel/bin/update_horde_config --user=username
    Note : Replace the actual username in the command.
