While installating cPanel ---
Beginning main installation.
2017-10-21 18:11:07 844 ( INFO): cPanel & WHM installation started at: Sat Oct 21 18:11:07 2017!
2017-10-21 18:11:07 845 ( INFO): This installation will require 20-50 minutes, depending on your hardware.
2017-10-21 18:11:07 846 ( INFO): Now is the time to go get another cup of coffee/jolt.
2017-10-21 18:11:07 847 ( INFO): The install will log to the /var/log/cpanel-install.log file.
2017-10-21 18:11:07 848 ( INFO):
2017-10-21 18:11:07 849 ( INFO): Beginning Installation v3...
2017-10-21 18:11:07 454 ( INFO): CentOS 7 (Linux) detected!
2017-10-21 18:11:07 470 ( INFO): Checking RAM now...
2017-10-21 18:11:07 531 ( INFO): Validating that the system hostname ('-information hidden') is a FQDN...
2017-10-21 18:11:07 555 ( INFO): Checking for NetworkManager now...
2017-10-21 18:11:07 573 (ERROR): ******************** ERROR ********************
2017-10-21 18:11:07 574 (ERROR): NetworkManager is installed and running, or
2017-10-21 18:11:07 575 (ERROR): configured to startup.
2017-10-21 18:11:07 576 (ERROR):
2017-10-21 18:11:07 577 (ERROR): cPanel does not support NetworkManager enabled
2017-10-21 18:11:07 578 (ERROR): systems. The installation cannot proceed.
2017-10-21 18:11:07 579 (ERROR):
2017-10-21 18:11:07 580 (ERROR): Please consult your system documentation to
2017-10-21 18:11:07 581 (ERROR): remove NetworkManager, replacing it with the
2017-10-21 18:11:07 582 (ERROR): network.service
2017-10-21 18:11:07 583 (ERROR): ******************** ERROR ********************
2017-10-21 18:11:07 584 (FATAL): Exiting...
Removing /root/installer.lock.
How to resolve this error?
