Good Day,
If SSH to the server works and WHM via root is still not accessible, you can use below steps to resolve it:
Prerequisite:
- You must have root access of the server for SSH..
- Check login_log and see if whostmgrd (cpHulk) has locked you out. The output will look something like the below:
If the above applies to you, try the following:
1. SSH to your server via root
2. Run the command:
The command above will whitelist your IP address.
3. Enable Password Reset
3. Change your password
4. Try login into the WHM now..
Prerequisite:
[root@cpanel log]# tail -f /usr/local/cpanel/logs/login_log [2018-02-12 16:16:13 +0000] info [whostmgrd] 11.22.33.44 - root "POST /login/?login_only=1 HTTP/1.1" DEFERRED LOGIN whostmgrd: brute force attempt (user root) has locked out IP 11.22.33.44 (3) [2018-02-12 16:17:15 +0000] info [cpaneld] 11.22.33.44 - causer "POST /login/?login_only=1 HTTP/1.1" DEFERRED LOGIN cpaneld: brute force attempt (user causer) has locked out IP 11.22.33.44 (3)
2. Run the command:
/scripts/cphulkdwhitelist <your_ip_address>
export ALLOW_PASSWORD_CHANGE=1
/scripts/chpass root "Your_New_Password"
