If this is your first visit, be sure to
check out the FAQ by clicking the
link above.
Before you can post: Click the register button below to proceed. To start viewing messages,
select the forum that you want to visit from the selection below.
First, you will need to check if rsyslog service is running on it. You can check the same using command.
[root@nda logrotate.d]# service rsyslog status
Redirecting to /bin/systemctl status rsyslog.service
* rsyslog.service - System Logging Service
Loaded: loaded (/usr/lib/systemd/system/rsyslog.service; enabled; vendor preset: enabled)
Active: active (running) since Sun 2018-03-04 14:26:13 AEST; 21s ago
Docs: man:rsyslogd(8)
http://www.rsyslog.com/doc/
Main PID: 12501 (rsyslogd)
CGroup: /system.slice/rsyslog.service
`-12501 /usr/sbin/rsyslogd -n
Mar 04 13:14:49 nda systemd[1]: Stopped System Logging Service.
Mar 04 14:26:13 nda systemd[1]: Starting System Logging Service...
Mar 04 14:26:13 nda rsyslogd[12501]: [origin software="rsyslogd" swVersion="8.24.0" x-pid="12501" x-info="http://www.rsyslog.com"] start
Mar 04 14:26:13 nda systemd[1]: Started System Logging Service.
If it is not running then restart the service and check /var/log/messages.
[root@nda logrotate.d]# service rsyslog restart
Even after restarting the service if you notice that your issue is not resolved then you will have to perform below-listed actions on the server.
Modify /etc/rsyslog.conf with your favorite editor either vi or nano
