I am getting this error while installing the mod_pagespeed on my cpanel server.
[root@sh29-413 24x7]# rpmbuild --rebuild ea-apache24-mod_pagespeed-latest-stable.src.rpm
Installing ea-apache24-mod_pagespeed-latest-stable.src.rpm
Executing(%prep): /bin/sh -e /var/tmp/rpm-tmp.7elTgp
+ umask 022
+ cd /root/rpmbuild/BUILD
+ wget -q -N -O mod-pagespeed-stable.rpm https://dl-ssl.google.com/dl/linux/d...ent_x86_64.rpm
+ exit 0
Executing(%build): /bin/sh -e /var/tmp/rpm-tmp.xFuYK3
+ umask 022
+ cpio -idmv
+ rpm2cpio mod-pagespeed-stable.rpm
./etc/cron.daily/mod-pagespeed
./etc/httpd/conf.d/pagespeed.conf
./etc/httpd/conf.d/pagespeed_libraries.conf
./usr/bin/pagespeed_js_minify
./usr/lib64/httpd/modules/mod_pagespeed.so
./usr/lib64/httpd/modules/mod_pagespeed_ap24.so
./var/cache/mod_pagespeed
./var/log/pagespeed
42497 blocks
+ mv usr/lib64/httpd/modules/mod_pagespeed.so usr/lib64/httpd/modules/mod_pagespeed_ap24.so .
+ /usr/bin/strip -g mod_pagespeed.so
+ /usr/bin/strip -g mod_pagespeed_ap24.so
+ exit 0
Executing(%install): /bin/sh -e /var/tmp/rpm-tmp.nfqrfL
+ umask 022
+ '[' /root/rpmbuild/BUILDROOT/ea-apache24-mod_pagespeed-latest-stable.x86_64 '!=' / ']'
+ rm -rf /root/rpmbuild/BUILDROOT/ea-apache24-mod_pagespeed-latest-stable.x86_64
++ dirname /root/rpmbuild/BUILDROOT/ea-apache24-mod_pagespeed-latest-stable.x86_64
+ mkdir -p /root/rpmbuild/BUILDROOT
+ mkdir /root/rpmbuild/BUILDROOT/ea-apache24-mod_pagespeed-latest-stable.x86_64
+ mkdir -p '/root/rpmbuild/BUILDROOT/ea-apache24-mod_pagespeed-latest-stable.x86_64%{_httpd_moddir}'
+ install -m755 mod_pagespeed.so '/root/rpmbuild/BUILDROOT/ea-apache24-mod_pagespeed-latest-stable.x86_64%{_httpd_moddir}/'
+ install -m755 mod_pagespeed_ap24.so '/root/rpmbuild/BUILDROOT/ea-apache24-mod_pagespeed-latest-stable.x86_64%{_httpd_moddir}/'
+ mkdir -p '/root/rpmbuild/BUILDROOT/ea-apache24-mod_pagespeed-latest-stable.x86_64%{_httpd_modconfdir}'
+ install -m 644 /root/rpmbuild/SOURCES/456_pagespeed.conf '/root/rpmbuild/BUILDROOT/ea-apache24-mod_pagespeed-latest-stable.x86_64%{_httpd_modconfdir}/'
+ /usr/lib/rpm/check-buildroot
find: '/root/rpmbuild/BUILDROOT/ea-apache24-mod_pagespeed-latest-stable.x86_64': No such file or directory
+ /usr/lib/rpm/redhat/brp-compress
/usr/lib/rpm/redhat/brp-compress: line 8: cd: /root/rpmbuild/BUILDROOT/ea-apache24-mod_pagespeed-latest-stable.x86_64: No such file or directory
+ /usr/lib/rpm/redhat/brp-strip /usr/bin/strip
+ /usr/lib/rpm/redhat/brp-strip-comment-note /usr/bin/strip /usr/bin/objdump
+ /usr/lib/rpm/redhat/brp-strip-static-archive /usr/bin/strip
+ /usr/lib/rpm/brp-python-bytecompile /usr/bin/python 1
Can't list /root/rpmbuild/BUILDROOT/ea-apache24-mod_pagespeed-latest-stable.x86_64
+ /usr/lib/rpm/redhat/brp-python-hardlink
+ /usr/lib/rpm/redhat/brp-java-repack-jars
Processing files: ea-apache24-mod_pagespeed-latest-stable.x86_64
error: File must begin with "/": %{_httpd_moddir}/*.so
error: File must begin with "/": %{_httpd_modconfdir}/*.conf
RPM build errors:
+ umask 022
+ exit 0
+ umask 022
+ cpio -idmv
./var/log/pagespeed
42497 blocks
+ exit 0
+ umask 022
RPM build errors:
