Whenever, you are getting the following error while installing the cPanel/WHM on the openvz VM:
Then, the issue seems to be the /etc/fstab file is missing, it should exist by default on the minimal installation of CentOS 7. If not, then you will need to create it using following commands so that you can proceed with the installation without any issue:
touch /etc/fstab
chmod 0640 /etc/fstab
Thank you.
2018-08-22 03:27:32 576 ( INFO): Checking for essential system files... 2018-08-22 03:27:32 579 (ERROR): Your system is missing the file /etc/fstab. This is an 2018-08-22 03:27:32 580 (ERROR): essential system file that is part of the base system. 2018-08-22 03:27:32 581 (FATAL): Please ensure the system has been properly installed.
touch /etc/fstab
Thank you.
