how to change the cPanel Language
  • how to change the cPanel Language
    Method 1:
    1. Login to your cPanel.
    2. under the Preferences section you will find the option as Change Language. Click on that option.
    This option allows you to change the language for the cPanel user.
    3. After that, you will find the Select a Language option, from the drop-down menu you can change the language. After the selection of the language click on the change icon.
    In this way, you can change the language of the cPanel account.
    Method 2:
    1. create .lang file under your root/home directory, i.e. /home/cPanel-user. In that enter the language that you wish to set.
    For example:
    If you want to set the language as Arabic then create .lang file under the /home/cPanel_user directory and write the name of the language:
    Arabic
    In this way, you can set the language for the cPanel user.
    2. If you want to revert the changes then just remove that .lang file.
    Then the language will set to the default one.
