Cachewall Config Error
  • Cachewall Config Error
    Hello,
    I tried installing cachewall in my vps. In the terminal everything is enabled and is working fine. But in WHM when I open cachewall plugin it says page cannot be found. And when cachewall is enabled my sites are down. Sites are up when I disable cachewall plugin in the terminal.
    I think some config i am missing. Can you please help me with this.
    Thanks,
    It looks like your WHM/cPanel has been updated to the latest, and the internal PHP of the cPanel was changed to the latest version and the Cachewall application API is encoded with ioncube loader for old PHP version. Due to that the Cachewall application API is not working, can you please try with updating the Cachewall on the server using the following command:
    yum update cachewall --enablerepo=cachewall-development
    If you are still receiving any errors then please register an account with us and submit a support ticket. We will check and assist you further.
      Thanks for the help.
