Storage size of PC Hard drive and RAM size
  • Storage size of PC Hard drive and RAM size
    Hi all,
    Just join this forum. cPanel installation is completely new to me although I have been using it quite sometimes.
    I'm going to install cPanel purely for learning not for production
    OS Linux - Ubuntu/Debian/CentOS
    What will be the minimum storage size of HD. I'll use SSD HD
    What will be the minimum size of RAM I need?
    Please advise. Thanks
    Regards
    Hi Satimis,
    Here are the requirements,
    For OS,
    • CentOS or RHEL
    For HDD,
    • Minimum: 20 GB
    • Recommended: 40 GB
    for RAM,
    • Minimum: 1 GB
    • Recommended: 2 GB
    A cPanel store login is mandatory after you install the cPanel on the server.
      Originally posted by Jayant R. Danech View Post
      Hi Satimis,
      For OS,
      • CentOS or RHEL
      For HDD,
      • Minimum: 20 GB
      for RAM,
      • Minimum: 1 GB
      • Recommended: 2 GB
      Hi Jayan,
      Thanks for your advice.
      Do I need a web server for running cPanel, to install LAMP?
      My old PC;
      HD - 120G SSD
      RAM - 8G
      CentOS 8 installed, running on old PC
      66G free in cs-root
      40G in cs-home
      I have 2~3 old 120G SSD resting on shelves. Can I install them on my old PC combing the storage of HD to 360G. If possible please advise HOW? Links would be appreciated. Thanks
      This is a test allowing me to learn cPanel installation, NOT for production.
      Regards
      • #4
        No, you do not require anything preinstalled. cPanel does install everything it requires to give you a up and running webserver.
        Do not install it on a server with fancy partition like / and /home. Keep it simple. It does not require any fancy partitioning.
        You can combine all the hard disks and use it on "/" without separate partitioning.
        • #5
          Hi Jayant,
          Whether I shouldn't install any other software on PC except OS, in my case CentOS 8?
          I shall use an Old PC testing installing cPanel. The HD is only a 120G A-DATA SSD and I doubt whether the storage space is sufficient? Just found another old Intel 120G SSD and installed it on the old PC
          # inxi -D
          Drives:
            Local Storage: total: 2.04 TiB used: 5.67 GiB (0.3%)
            ID-1: /dev/sda vendor: Intel model: SSDSC2CT120A3 size: 111.79 GiB
            ID-2: /dev/sdb vendor: Western Digital model: WD2002FAEX-007BA0
            ID-3: /dev/sdc vendor: A-Data model: SX900 size: 119.24 GiB
          # df -h
          Filesystem           Size  Used Avail Use% Mounted on
          devtmpfs             3.8G     0  3.8G   0% /dev
          tmpfs                3.8G   26M  3.8G   1% /dev/shm
          tmpfs                3.8G  9.6M  3.8G   1% /run
          tmpfs                3.8G     0  3.8G   0% /sys/fs/cgroup
          /dev/mapper/cs-root   70G  4.9G   66G   7% /
          /dev/sdc2           1014M  242M  773M  24% /boot
          /dev/mapper/cs-home   40G  618M   40G   2% /home
          /dev/sdc1            599M  7.3M  592M   2% /boot/efi
          tmpfs                767M  5.8M  762M   1% /run/user/1000
          I have no idea how to combine the space of 2 SSD drives before or during installing cPanel ? I'll format Intel 120G SSD as ext4 later.
          On Internet I found following link;
          Installation Guide - Installation
          Whether I should follow their steps. Please advise. Thanks
          Regards.
          • #6
            -> Nothing is required but freshly installed OS.
            HTML Code:
            Like I said previously, there is no point in keeping 2 different partitions when you can use only one partition, so that does not limit any other capabilities in the future. I will suggest you remove the /home and extend the existing cs-root to full capacity.
            -> This is the official installation link for cPanel, so you can follow this without any doubt.
            • #7
              Hi
              Just made following test of cPanel installation;-
              OS : CentOS 8 freshly installed
              SSD Hard drive : 120G
              no /home
              # lvs
                LV   VG Attr       LSize   Pool Origin Data%  Meta%  Move Log Cpy%Sync Convert
                root cs -wi-ao---- 109.00g
                swap cs -wi-ao----   7.80g
              IP : 192.168.1.112
              # curl -o latest -L http://httpupdate.cpanel.net/latest && sh latest
                % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                               Dload  Upload   Total   Spent    Left  Speed
              100   249  100   249    0     0    252      0 --:--:-- --:--:-- --:--:--   251
              100 35779  100 35779    0     0  14663      0  0:00:02  0:00:02 --:--:-- 44835
              Verifying archive integrity... All good.
              Uncompressing cPanel & WHM Installer......
                      ____                  _
                  ___|  _ \ __ _ _ __   ___| |
                 / __| |_) / _` | '_ \ / _ \ |
                | (__|  __/ (_| | | | |  __/ |
                 \___|_|   \__,_|_| |_|\___|_|
                Installer Version v00107 r19e129efd75d93f8e0c72bcd3e3eee84c6fb291d
              Beginning main installation.
              2021-04-15 05:20:23  993 [4095] ( INFO): cPanel & WHM installation started at: Thu Apr 15 05:20:23 2021!
              2021-04-15 05:20:23  994 [4095] ( INFO): This installation will require 10-50 minutes, depending on your hardware and network.
              2021-04-15 05:20:23  995 [4095] ( INFO): Now is the time to go get another cup of coffee/jolt.
              2021-04-15 05:20:23  996 [4095] ( INFO): The install will log to the /var/log/cpanel-install.log file.
              2021-04-15 05:20:23  997 [4095] ( INFO):
              2021-04-15 05:20:23  998 [4095] ( INFO): Beginning Installation v3...
              2021-04-15 05:20:23  613 [4095] (DEBUG):   Detected distro “centos-stream-release”, version “8.5”, arch “x86_64”
              2021-04-15 05:20:23 2576 [4095] (DEBUG):   - ssystem [BEGIN]: rpm -q dnf
              2021-04-15 05:20:23 2576 [4095] (DEBUG):     dnf-4.4.2-11.el8.noarch
              2021-04-15 05:20:23 2576 [4095] (DEBUG):   - ssystem [END]
              2021-04-15 05:20:23  641 [4095] ( INFO): centos-stream 8.5 (Linux) detected!
              2021-04-15 05:20:23  656 [4095] ( INFO): Checking RAM now...
              2021-04-15 05:20:23  717 [4095] ( INFO): Validating that the system hostname ('localhost.localdomain') is a FQDN...
              2021-04-15 05:20:23  723 [4095] (ERROR):
              2021-04-15 05:20:23  724 [4095] (ERROR): ********************* ERROR *********************
              2021-04-15 05:20:23  725 [4095] (ERROR):
              2021-04-15 05:20:23  726 [4095] (ERROR): Your hostname (localhost.localdomain) is invalid, and must be
              2021-04-15 05:20:23  727 [4095] (ERROR): set to a fully qualified domain name before installing cPanel.
              2021-04-15 05:20:23  728 [4095] (ERROR):
              2021-04-15 05:20:23  729 [4095] (ERROR): A fully qualified domain name must contain two dots, and consists of two parts: the hostname and the domain name.
              2021-04-15 05:20:23  730 [4095] (ERROR): You can update your hostname by running `hostname your-hostname.example.com`, then re-running the installer.
              2021-04-15 05:20:23  732 [4095] (ERROR): ********************* ERROR *********************
              2021-04-15 05:20:23  733 [4095] (FATAL): Exiting...
              Removing /root/installer.lock.
              Failed
              # cat /etc/hostname
              # cat /etc/hosts
              127.0.0.1   localhost localhost.localdomain localhost4 localhost4.localdomain4
              ::1         localhost localhost.localdomain localhost6 localhost6.localdomain6
              I have domain registered. This is only a test not for production
              Please advise how to change hostname to proceed. Thanks
              Regards
