How to install Tomcat on Cpanel ?
  • How to install Tomcat on Cpanel ?
    Can anybody guide me on how to install Tomcat on Cpanel latest edition ? I don't see any option to install tomcat.
    Unfortunately, the latest cPanel build are shipped with EasyApache 4 and it does not support tomcat installation in it..
      You should try the following steps to install tomcat 8 manually on the cpanel server.
      Tomcat requires having java installed on your machine, you can install it using the below command from shell:-
      yum install java
      You can verify the java using the following command:-
      java -version
      Output:
      [root@tomcat ~]# java -version
      openjdk version "1.8.0_151"
      OpenJDK Runtime Environment (build 1.8.0_151-b12)
      OpenJDK 64-Bit Server VM (build 25.151-b12, mixed mode)
      You will need to create a normal tomcat user for running the Tomcat service using the following commands from shell:-
      groupadd tomcat
      useradd -g tomcat -d /opt/tomcat -s /bin/nologin tomcat
      Download the latest version of the Apache Tomcat from the website and save it to your home directory.
      wget http://apache.mirrors.ionfish.org/tomcat/tomcat-8/v8.0.48/bin/apache-tomcat-8.0.48.tar.gz
      Extarct the file and move the content under /opt/tomcat/ folder.
      tar -zxvf apache-tomcat-*.tar.gz
      mv apache-tomcat-8.0.48/* /opt/tomcat/
      Change the ownership of the directory so that tomcat user can write files in it.
      chown -R tomcat:tomcat /opt/tomcat/
      Apache Tomcat can be started and stopped using the script within the package:-
      Start Tomcat
      [root@tomcat src]# cd /opt/tomcat/bin/
      [root@tomcat bin]# sh startup.sh
      Using CATALINA_BASE: /opt/tomcat
      Using CATALINA_HOME: /opt/tomcat
      Using CATALINA_TMPDIR: /opt/tomcat/temp
      Using JRE_HOME: /usr
      Using CLASSPATH: /opt/tomcat/bin/bootstrap.jar:/opt/tomcat/bin/tomcat-juli.jar
      Tomcat started.
      Stop tomcat:-
      [root@tomcat bin]# cd /opt/tomcat/bin/
      [root@tomcat bin]# sh shutdown.sh
      You can create a tomcat systemd service file by adding a below code in the file:-
      [root@tomcat tomcat]# cat /etc/systemd/system/tomcat.service
      [Unit]
      Description=Apache Tomcat 8.x Web Application Container
      Wants=network.target
      After=network.target
      [Service]
      Type=forking
      Environment=JAVA_HOME=/usr/lib/jvm/java-1.8.0-openjdk-1.8.0.151-5.b12.el7_4.x86_64/jre
      Environment=CATALINA_PID=/opt/tomcat/temp/tomcat.pid
      Environment=CATALINA_HOME=/opt/tomcat
      Environment='CATALINA_OPTS=-Xms512M -Xmx1G -Djava.net.preferIPv4Stack=true'
      Environment='JAVA_OPTS=-Djava.awt.headless=true'
      ExecStart=/opt/tomcat/bin/startup.sh
      ExecStop=/opt/tomcat/bin/shutdown.sh
      SuccessExitStatus=143
      User=tomcat
      Group=tomcat
      UMask=0007
      RestartSec=10
      Restart=always
      [Install]
      WantedBy=multi-user.target
      Reload systemd daemon.
      systemctl daemon-reload
      To start the Tomcat service; run:
      systemctl start tomcat
      Check the status of Tomcat, run:
      systemctl status tomcat
      Enable the auto start of Tomcat service on system start, run:
      systemctl enable tomcat
      Output:
      [root@tomcat tomcat]# systemctl enable tomcat
      Created symlink from /etc/systemd/system/multi-user.target.wants/tomcat.service to /etc/systemd/system/tomcat.service.
      [root@tomcat tomcat]# systemctl status tomcat.service
      ● tomcat.service - Apache Tomcat 8.x Web Application Container
      Loaded: loaded (/etc/systemd/system/tomcat.service; disabled; vendor preset: disabled)
      Active: active (running) since Mon 2018-01-01 08:27:05 UTC; 5s ago
      Process: 2663 ExecStart=/opt/tomcat/bin/startup.sh (code=exited, status=0/SUCCESS)
      Main PID: 2670 (java)
      CGroup: /system.slice/tomcat.service
      └─2670 /usr/lib/jvm/java-1.8.0-openjdk-1.8.0.151-5.b12.el7_4.x86_64/jre/bin/java -Djava.util.logging.config.file=/opt/tomcat/conf/logging.proper...
      Jan 01 08:27:05 tomcat.testname.com systemd[1]: Starting Apache Tomcat 8.x Web Application Container...
      Jan 01 08:27:05 tomcat.testname.com startup.sh[2663]: Tomcat started.
      Jan 01 08:27:05 tomcat.testname.com systemd[1]: Started Apache Tomcat 8.x Web Application Container.
      Verify Apache Tomcat in working fine or not. Tomcat runs on port no 8080. You can check whether the service is listening on port 8080 or not.
      [root@tomcat tomcat]# netstat -antup | grep 8080
      tcp 0 0 0.0.0.0:8080 0.0.0.0:* LISTEN 2670/java
      You may need to allow port 8080 in the firewall:-
      firewall-cmd --permanent --add-port=8080/tcp
      firewall-cmd --reload
      OR
      iptables -A INPUT -p tcp -s IPaddress -m tcp --dport 8080 -j ACCEPT
      service iptables savae
      service iptables restart
      The Web and Host Manager are password protected, requires user name and password to access. Only the user with the “manager-gui” and “admin-gui” role is allowed to access.
      These users and roles are defined in tomcat-users.xml.
      nano /opt/tomcat/conf/tomcat-users.xml
      You will need to add the following two lines just above the last line.
      <role rolename="admin-gui,manager-gui"/>
      <user username="admin" password="tomcat" roles="manager-gui,admin-gui"/>
      Restart the Tomcat.
      systemctl restart tomcat
      Open the tomcat URL in the browser, you can see the Tomcat’s default page.
      Click image for larger version  Name:	tomcat default.PNG Views:	1 Size:	159.7 KB ID:	415
      Web Host Manager required Login to connect:-
      http://ipaddress:8080
      Username : admin
      Password : tomcat
      Now, you can deploy a new application, deploy an application on specified context, start, stop, reload, and un-deploy an application.
      That's it.
