How can I install Django on cPanel. Please provide me the correct steps.
How to install Django on cPanel?
We tried to install Django on a test cPanel server with no accounts on it.
We faced multiple issues but had a work around to fix it.
Step 1: Start by installing cPanel on the server.
Step 2: In order to run Django websites you will need mod_wsgi Apache module.Code:cd /home && curl -o latest -L https://securedownloads.cpanel.net/latest && sh latest
You may end up with an error message " apxs command not found ".Code:cd /usr/local/src/ wget http://storage.googleapis.com/google-code-attachments/modwsgi/issue-214/comment-0/custom_opt_mod-mod_wsgi.tar.gz tar -xvzf custom_opt_mod-mod_wsgi.tar.gz tar -xvzf ./Cpanel/Easy/ModWSGI.pm.tar.gz cd mod_wsgi-3.3 make && make install
The reason for this is you are running latest Apache version 2.4.29 with EA4.
Step 3 : To check the dependencies for aspx you must run following command on the server.
The output will be similar to the below result.Code:yum provides apxs
ea-apache24-devel-2.4.29-6.6.1.cpanel.x86_64 : Development interfaces for the Apache HTTP server
Repo : EA4
Matched from:
Filename : /usr/bin/apxs
Step 4: check the one that matches your Apache version and run the command as below.
Step 5: This will install apxs and can be verified as.Code:yum install ea-apache24-devel-2.4.29-6.6.1.cpanel.x86_64
Step 6: Thereafter, check the python version and its binary location.Code:ls -la /usr/bin/apxs -rwxr-xr-x 1 root root 19379 Jan 17 14:01 /usr/bin/apxs
Code:python -V Python 2.7.5
Code:which python /usr/bin/python
Step 7: Go back and complete mod_wsgi installation.
Step 8: Unfortunately, ended up with another error "conn_rec' has no member named 'remote_ip'' and "conn_rec' has no member named 'remote_addr''. To fix this, we modified the code as below.Code:cd /usr/local/src/ cd mod_wsgi-3.3 ./configure --with-apxs=/usr/bin/apxs --with-python=/usr/bin/python make && make install
Code:cp mod_wsgi.c mod_wsgi.c_bk sed s/remote_ip/client_ip/g -i mod_wsgi.c sed s/remote_addr/client_addr/g -i mod_wsgi.c
Success !!!Code:make && make install
You will see the output on the screen as below which will give you the location of the libraries installed for the module mod_wsgi (It is installed at /usr/lib64/apache2/modules/mod_wsgi.so)
Libraries have been installed in:
If you ever happen to want to link against installed libraries
in a given directory, LIBDIR, you must either use libtool, and
specify the full pathname of the library, or use the `-LLIBDIR'
flag during linking and do at least one of the following:
- add LIBDIR to the `LD_LIBRARY_PATH' environment variable
during execution
- add LIBDIR to the `LD_RUN_PATH' environment variable
during linking
- use the `-Wl,-rpath -Wl,LIBDIR' linker flag
- have your system administrator add LIBDIR to `/etc/ld.so.conf'
See any operating system documentation about shared libraries for
more information, such as the ld(1) and ld.so(8) manual pages.
chmod 755 /usr/lib64/apache2/modules/mod_wsgi.so
You will now have to include it in the Apache configuration.
Step 9 : Login to WHM Home >> Service Configuration >> Apache Configuration>> Include Editor >> edit Pre Main Include and update with below code.
Restarting Apache Web ServerCode:LoadModule wsgi_module /usr/lib64/apache2/modules/mod_wsgi.so AddHandler wsgi-script .wsgi
Apache successfully restarted. Signaled successfully. This is a sign that you have everything in place.
Step 10: Lastly, Install Django.
Django softwares are available at https://pypi.python.org/simple/django/
We installed the latest one.
This will process and install Django on your cPanel server.Code:https://pypi.python.org/simple/django/ wget https://pypi.python.org/packages/31/b7/8ad017c3e81635bb12c6d41b56fdbf4bb52eb30aea7f45cfeea61607bab8/Django-1.11.9.tar.gz#md5=08ad028fc50ee961dea35e1e1f657b65 tar -xvzf Django-1.11.9.tar.gz cd Django-1.11.9 python setup.py install
Now you may go ahead and test you Django application !!!
