I need APCu extension for my application, please could you provide me steps to install it on cPanel server.
How to install APCu extension on cPanel?
Dear Priyanka,
One of the quickest solution to install APCu on cPanel with EasyApache 4 is as follows.
Please make sure that you have Engintron installed on the server. If you do not have it and need steps then you can follow our link https://forums.24x7servermanagement....-cpanel-server for a detailed explanation.
Once you have everything in place then just go ahead and execute commands on the server as stated below.
Thats it !! APCu extension is installed and added to the php.ini file for use.Code:$ chmod +x /usr/local/src/engintron/utilities/install_apcu_in_cpanel_ea4.sh $ /usr/local/src/engintron/utilities/install_apcu_in_cpanel_ea4.sh
- Likes 1
