How to Redirect users to SSL connections in Plesk
  • How to Redirect users to SSL connections in Plesk
    To ensure that visitors to your website must use a secure connection, you will need to redirect them to SSL.
    1. Log in to Plesk.
    2. click on Websites & Domains.
    3. Locate the domain that you want to configure, and click on Hosting Settings.
    4. Under the Security section, select SSL/TLS support and Permanent SEO-safe 301 redirect from HTTP to HTTPS checkboxes.
    5. In the Dropdown box for Certificate, select the SSL certificate that you want to use for your site.
    It should show your domain name in the drop-down.
    6. Click on OK. Your site now onwards will use a secure connection for all web page requests.
