Centos Web panel :- Server needs to be upgraded
  • Centos Web panel :- Server needs to be upgraded
    Whenever, you can't access the Centos Web panel and showing below output on screen
Name:	CWP upgrade 2.PNG
    then, you will need to update CWP panel to latest version by using the following steps:-
    1) If your server is using old MySQL version, then you will need upgrade it to latest MySQL 5.5 or MariaDB.
    MySQL upgrade steps: -
    cd /usr/local/src
    wget http://dl1.centos-webpanel.com/files/el6/cwpupgrade/mysql.sh
    sh mysql.sh
    Then, proceed with the CWP upgrade using the following commands:-
    cd /usr/local/src
    wget http://dl1.centos-webpanel.com/files/el6/cwpupgrade/cwpsrv.sh
    sh cwpsrv.sh
    and if you wish to upgrade the Apache then follow below steps:
    Note :- Before proceeding with the apache upgrade, logged into CWP admin panel and check whether you are running apache only under Apache Settings >> Select WebServers, don't forget to rebuild vhosts.
    cd /usr/local/src
    wget http://dl1.centos-webpanel.com/files/el6/cwpupgrade/apache.sh
    sh apache.sh
    If there is something wrong after upgrade then you can try below commands:-
    yum reinstall cwp-httpd cwp-suphp
    RESTORE
    and if something goes wrong you can restore your server apache and cwpsrv using the following commands.
    cd /usr/local/src
    sh cwpsrv.sh restore
    sh apache.sh restore
    If you have any further issues, please let us know.
