Error: rpmdb open failed
  • Error: rpmdb open failed
    Just sharing one RPM database corrupted issue on the Centos server.
    I was trying to update the system packages on the server, but I was getting the below error.
    [root@server ~]# yum update
    rpmdb: Thread/process 140135/140671782139648 failed: Thread died in Berkeley DB library
    error: db3 error(-30974) from dbenv->failchk: DB_RUNRECOVERY: Fatal error, run database recovery
    error: cannot open Packages index using db3 -  (-30974)
    error: cannot open Packages database in /var/lib/rpm
    CRITICAL:yum.main:
    I suspected an issue with the yum cache, so I tried to clean it but it did not work.
    [root@server ~]# yum clean
    CRITICAL:yum.main:
    Then, I tried to rebuild the RPM database but error was still the same:
    [root@server ~]# rpm --rebuilddb
    At last, I found the actual issue. The rpm db was corrupted so I repaired it using the below steps:
    [root@server ~]# ls /var/lib/rpm
    Basenames     __db.001  __db.003  Dirnames     Group       Name          Packages     Provideversion  Requirename     Sha1header  Triggername
    Conflictname  __db.002  __db.004  Filedigests  Installtid  Obsoletename  Providename  Pubkeys         Requireversion  Sigmd5
    [root@server ~]# rm -f /var/lib/rpm/__*
    [root@server ~]#
    It works!!.
