Steps to install Joomla 3.8.3 on localhost using XAMPP
  • Steps to install Joomla 3.8.3 on localhost using XAMPP
    Steps:
    1. Install XAMPP on your machine.
    2. Start the XAMPP server:
    Click image for larger version  Name:	xampp.png Views:	1 Size:	37.2 KB ID:	474
    3. Install Joomla by using the following link:
    Download the free open source CMS Joomla! and start building your awesome website.
    Click image for larger version  Name:	download_file.png Views:	1 Size:	261.3 KB ID:	491
    4. Once the file is downloaded copy that folder under C:/xampp/htdocs and paste downloaded file.
    5. Extract the file and in the browser put localhost/folder_name
    eg. localhost/joomla_project
    6. Automatically one window will appear:
    Click image for larger version  Name:	form_details.png Views:	1 Size:	76.8 KB ID:	476
    ​Fill the form like the site_name, email, username ,password and confirm administrator password.
    Choose default username as admin or yourname, choose password randomly and administrator password same as username password and then click on Next.
    7.
    Click image for larger version  Name:	database_config1.png Views:	1 Size:	67.3 KB ID:	477
    Select the database type as MYSQLi ,hostname as localhost, username as root, create the database and then click on Next.
    8. Steps to create database:
    On browser put localhost/phpmyadmin
    Click image for larger version  Name:	create_table.png Views:	1 Size:	104.8 KB ID:	478
    Create the database and put the database name above as same as which is created here.
    8. After clicking Next
    Click image for larger version  Name:	installation.png Views:	1 Size:	81.6 KB ID:	479
    Above Window will appear and click on Install.
    9. Click image for larger version  Name:	installating.png Views:	1 Size:	38.3 KB ID:	481
    If the setup goes in this way only without stopping then open joomla.sql file under:
    C:/xampp/htdocs/folder_name/sql/mysql/joomla.sql file:
    In that file replace InnoDB word with MyISAM
    10. Again refresh the page it will redirect again to installation page:
    Click image for larger version  Name:	form_details.png Views:	1 Size:	76.8 KB ID:	483
    It will again ask for Confirm administrator password fill same as username password .
    11. Click on Next-> Next-> Install.
    12. Now the Joomla will install successfully on a localhost :
    Click image for larger version  Name:	installation-complete.png Views:	2 Size:	121.9 KB ID:	484
    11. Click on Administrator :
    Type the username and password which were set in installation.
    12. Click image for larger version  Name:	joomla_home.png Views:	2 Size:	27.4 KB ID:	489
    Now you can access to login form.
    13. We can access through Joomla Control Panel by going in the administrator folder :
    In the browser put : localhost/joomla_project/administrator
    Click image for larger version  Name:	joomla_controlpanel.png Views:	2 Size:	92.3 KB ID:	492
    This how you can install joomla on a localhost
    Thanks for such a nice post !!
