Revolution Slider Not Working
  • Revolution Slider Not Working
    Hello,
    I have installed the Revolution slider plugin , but it seems not to be working I am facing 404 error.
    The exact error which I am facing is "404 page not found".
    Can anyone advice.
    It seems to be ModSecurity issue, You can try disabling your ModSecurity from cPanel >> ModSecurity >> Under Domains > Status- Off
    Once your domain's ModSecurity is Off, you can just try creating a Test page and try adding a ''Revolution slider'' on it and check if it works.
    Revolution slider can be installed from Login to your Wordpress admin panel >> go to Plugins > Add New. Browse to the plugin archive and select it. Then click Install Now and the plugin will be installed shortly > Import the ''Revolution slider'' and add the zip file.
    Let me know uf the issue still persist, Thanks!
      Thank you Sushmeet it works!!!
