Hello,
Most Important WordPress Plugins are:
1. OptinMonster:
OptinMonster is the most popular conversion rate optimization software.
It allows you to convert abandoning website visitors into email subscribers.
If you want to grow your email list, then this is a must have this plugin installed on your website.
2. WPForms
WPForms is the friendly contact form plugin for WordPress.
This drag & drop online form builder allows you to easily create contact forms, email subscription forms, order forms etc.
3. MonsterInsight:
MonsterInsights is the best Google Analytics plugin for WordPress.
It allows you to connect your website with Google Analytics, so that you can track the number of visitors visiting the website.
4.Constant Contact
Constant Contact is one of the best email marketing service providers.
It allows you to build an email lists and send emails to your subscribers.
5. BackupBuddy
BackupBuddy is used for taking the backup of the system.
In terms of security there’s no better security than having a reliable backup system.
6. Yoast SEO
Yoast SEO is one of the most popular WordPress plugins.
It allows you to optimize your WordPress site for search engines.
7. W3 Total Cache
W3 Total Cache allows you to serve compressed and cached files to your visitors.
This reduces the load on your server and your website becomes faster
8. CSS Hero
CSS Hero is a WordPress plugin that allows you to customize any WordPress theme without writing a single line of code.
1. OptinMonster:
2. WPForms
3. MonsterInsight:
4.Constant Contact
5. BackupBuddy
6. Yoast SEO
7. W3 Total Cache
8. CSS Hero
