RPM check fails with error system cannot update the /var/cpanel/sysinfo.config.
  • RPM check fails with error system cannot update the /var/cpanel/sysinfo.config.
    I am getting below error when I am trying to check the RPM system on the centos 6 server:
    ERROR: The system cannot update the /var/cpanel/sysinfo.config file because it cannot determine your distribution's major version.
    Run the following command: rpm -qf --queryformat '%{VERSION}\n' /etc/redhat-release
    Output other than the numbers 6 or 7 indicates a problem. Open a support ticket or resolve the issue manually.
    Can anyone here guide me on how to fix this?
    It appears that the cPanel server is not able to generate the system information, which may be a result of an issue with the RPM database. The below command generates the error in the backend:
    # /usr/local/cpanel/scripts/gensysinfo
    To resolve this, you will have to rebuild the RPM database.. All you have to do is login to your WHM and rebuild the RPM Database:
    Path: WHM Home » Software » Rebuild RPM Database ..
    Execute the gensysinfo command again and you will see the information now is properly generated..
    I hope this helps you..
      Great ! This has fixed the issue. :-)
      Thanks.
